ARP head stud users inside...
Old Mar 10, 2003 | 02:32 PM
C_Williams's Avatar
Default ARP head stud users inside...
What torque specs did you use?
thanks in advance
Old Mar 10, 2003 | 02:37 PM
BTL FED's Avatar
Default Re: ARP head stud users inside...
good question, I would like to know as well
Old Mar 10, 2003 | 02:54 PM
FEAR THE LS1's Avatar
I would like to know also.
Also do they use the same torque patter as regular head bolts?
I'm sure a sponsor like ARE, MTI etc that installs these regularly can answer these questions in a second.
Old Mar 10, 2003 | 05:04 PM
joghotrod's Avatar
The ARP paper that came with my head studs says to torque to 70ft/lbs with molylube or 85 with 30wt motor oil. Good luck. Jimmy
Old Mar 10, 2003 | 05:17 PM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by joghotrod:
<strong> The ARP paper that came with my head studs says to torque to 70ft/lbs with molylube or 85 with 30wt motor oil. Good luck. Jimmy </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually, if you read further down, it says for Aluminum heads, to use 65 ft/lbs to account for the expansion. Either way, it probably doesn't matter. I used 65 though.
And I followed the same torque pattern as regular head bolts.
Old Mar 10, 2003 | 05:25 PM
Sears's Avatar
!Dial-up Director
Studs get 5ft/lbs and the nuts get 75ft/lbs with the moly lube, stock head gaskets. Checked them recently and they are all still in spec.
Justin
Old Mar 10, 2003 | 06:10 PM
LS1derfull's Avatar
I recc; torque in sequence, back off and retorque to help settle gaskets. Overnight would be better.
