PV clearance with this big of a cam???
cam: 232*/240* 595"/608" on a 112
Its a comp cam.
Thanks!
. I would run with a double spring setup, and titanium retainers. Depending on the double spring you pick determines the head machine work you will need. There are some out there that will work with the stock spring seats and need no machining.Rich
