Katech Timing Chain Slack
Old Nov 24, 2013 | 11:02 PM
ls1 1990 VN's Avatar
Originally Posted by usdmholden
I measured the slack on my Cloyes 9-3153 hex adjust set yesterday because I was curious. The slack was .117" from slack to tight with the calipers in roughly the same position as the pictures shown in the thread I linked above.
Be interested in what the hex a just & C5R chain is, ie: item# 9-3658TX9Z
I never had it check when it was installed
Old Nov 25, 2013 | 09:23 AM
usdmholden's Avatar
I'm sure the higher end Cloyes set is better than the standard Cloyes set, but the question to ask is, how good is good enough? Do you need the best of the best for an extra $150 price premium?
My 9-3153 was $115 from Scoggin Dickey vs $266 from Jegs for the premium part. I don't plan on doing any 24 hour endurance races with my Mustang, so I suspect the standard part will work fine. Also, I had several Cloyes timing sets on small block Fords, and the standard parts always worked fine in them.
