LS1/LS6 rod question
Old May 7, 2004 | 10:24 PM
TK 14 SS's Avatar
Default LS1/LS6 rod question
I'm in the process of "rebuilding" the LS1 due to spinning a bearing and bending my crankshaft, etc...
So, I picked up a set of ARP "cracked rod" bolts and a set of replacemnet rods out of an LS6 from Lingenfelter (via ebay). So as I'm putting the new bolts into the rods and I notice the lack of the little bushing in the "new" rod ends. Can anyone explain this? or do you think LPE removed them for some reason? I'm assuming that I need these???
Thanks!
Troy
Old May 8, 2004 | 06:07 AM
stevieturbo's Avatar
Im not totally certain, but could the pin be a press fit, instead of a floating fit ?
Old May 8, 2004 | 09:58 AM
TK 14 SS's Avatar
yeah, the pin is a press fit but what I'm wondering about is a little bushing in the hole that the rod bolt goes through.
Old May 8, 2004 | 04:02 PM
Redline-Motorsports's Avatar
That bushing is a dowel to keep the rod cap in alignment with the rod. You need to have it!
Old May 8, 2004 | 04:16 PM
TK 14 SS's Avatar
Okay, thank you very much!
