Broken yella terra rocker arm
Old Dec 22, 2013 | 11:52 AM
Greenthumb LS1's Avatar
Default Broken yella terra rocker arm
On Friday we had my camaro on the dyno and had a rocker break right as we began the first wot pull. I've had these on my car since 2009 and had just swapped springs from the stock trick flow 215cc ones to brian tooley .650's. Im guessing my old springs were a little weaker than I had thought. Anyways I'm pretty sure my yellas were the old design because the 1.7 is stamped to the left of the center on top of the rocker. Anyways I'm kinda scared to get a another set of these, what other rockers do you guys recomend for trick flow heads?
Old Dec 22, 2013 | 12:31 PM
96capricemgr's Avatar
PM guides and stock rockers with the trunnion upgrade.
Old Dec 22, 2013 | 12:36 PM
I always thought the TFS heads had bronze guides. I also thought u couldn't use stock rockers with TFS heads. AFR's you could use stock. But again I'm all ears.
Old Dec 22, 2013 | 12:42 PM
Burken01's Avatar
I read awhile back you can shim the stockers to get a decent wipe pattern with TFS heads..
Might want to contact tooley to see every option available with those heads
Old Dec 22, 2013 | 01:10 PM
RedDeadG8's Avatar
stock rockers with the trunion upgrade
Old Dec 22, 2013 | 01:21 PM
What I meant and others are telling you is that PM guides can be put in the trickflow heads.
Old Dec 22, 2013 | 01:49 PM
Oh ok for sure I get it. I'll call up Brian tooley too just to get his opinion. Thanks for the responses guys.
Old Dec 22, 2013 | 02:39 PM
trans_am7935's Avatar
OP what size is your cam? i am runin .624 lift on mine which is why i went with Yella Terra's,
been runnin Yella Terra's for about 3 years now, with many days at the auto-x track. No break yet, but i have the newer style ultralights
Old Dec 22, 2013 | 04:43 PM
It a tony mamo spec 231/235 621/621 on a 115. The car is also Procharged putting down 802/725 to the wheels.
Old Dec 22, 2013 | 06:16 PM
vettenuts's Avatar
You may want to simply replace them with the Yella Terra Generation III rocker. They are stronger for the higher force springs. I would verify they can handle your open spring forces though. I think Brian is going to recommend not using stock rockers, unless you want to replace guides in 10K miles.
Two other recommendations:
1. Ensure the wipe pattern is perfect, which may require shim thickness other than provided by Yella Terra. Mine required different shims on my AFR heads.
2. If you haven't already, go with larger OD pushrods. I went with 3/8" double taper and noticed an immediate change in the upper RPM. In other words, they were bending.
Old Dec 25, 2013 | 11:18 AM
RedDeadG8's Avatar
I have gone through 2 sets of YT rockers since 2010, I think i had the GEN I and II. my first set broke at the pedestal. the second set seized rotating and took part of my motor with it. So I am biased when I say I will never use YT again. less than 20k miles was put on the car in that period. YT did replace my 1st set free of cost, and I just said screw it with the 2nd set. went with another company.
Old Dec 25, 2013 | 04:53 PM
As i stated earlier, i have the "Gen III" Yella Terra's and they are great. My open spring pressures are almost 500 in lbs. These are the springs i have:
http://www.texas-speed.com/p-473-pre...pring-kit.aspx
So the Yella Terra's are definitely able to handle harsh spring pressures. I have had my motor up to 6900rpm (+/- 50 rpm) as well on the dyno, with the redline currently set at 6800.
Old Dec 27, 2013 | 08:01 AM
vettenuts's Avatar
Understand why you would be gun shy at this point based on your past experience. However, the OP appears to have bronze guides and very high lift. Stock rockers will FUBAR the guides pretty quickly (I would guess <10K miles). My personal approach would be the YT's Gen III with a very narrow wipe pattern to minimize guide wear and then the stiffest pushrod I could fit in the hole, either straight 3/8" or a 3/8" double taper. The stiffer pushrods will help with valve bounce and shock loading into the rockers.
If money were no object, I would go with the Jesel Pro Steel, but they are over $2,000 for a set.
Old Dec 27, 2013 | 08:53 AM
JakeFusion's Avatar
Super Hulk Smash
vettenuts makes a good recommendation.
I'd run the 3/8" pushrod since they fit the TFS heads regardless of the rocker used.
But, I'd replace the bronze guides with PM guides and run stock rockers if it were my motor.
Old Dec 30, 2013 | 01:23 PM
ViaBellator's Avatar
I too had a yella terra rocker break and take a piston and head with it. I also run TFS heads.
When I put it back together, I put stock rockers in it. The car has run better than it ever did with the YTs, but I am well aware of the premature wear with the bronze guides.
My plan, if you can call it that, is to run it as is until/unless I start to see an issue and then have the bronze guides replaced with powedered metal guides and stick with the stock rocker.
Old Dec 31, 2013 | 07:58 PM
miami993c297's Avatar
The YT Utralite cannot technically be worse than stock rocker rationally in any manner...BUT...only if your entire valve-train is perfectly balanced and matched between each of the component after that upgrade!!!
Other of that, someone misunderstood valve-train dynamic and it's better to stick in the lower league.
Christian
Old Dec 31, 2013 | 08:25 PM
sepsis's Avatar
Yea, I've seen broken YT rocker threads/posts a few times on here.
I wouldn't put them in my car if they were given to me for free.
Old Dec 31, 2013 | 08:43 PM
Christian
Spoken like someone who has never had a valve drop due to a broken YT rocker. Better is relative. Better running than not in this case.
Old Dec 31, 2013 | 08:53 PM
Hey hey...you are quite correct...
My engine is using YT Ultra Lites Gen III and revving on a daily bases to 7500 rpm, 664hp flywheels, bumping in the rev limiter when needed...something must be well done!
Sorry for your misadventure (costly one I guess).
Happy New Year
Christian
Old Jan 1, 2014 | 08:20 AM
vettenuts's Avatar
Many don't look at pushrods, and they can be a major contributor to broken parts, especially aluminum rockers. 5/16" pushrods are not stiff enough once you start getting into aftermarket springs. Hardened pushrods are not stiffer, and stiffness is best achieved by a large OD and not a smaller ID (thicker wall). In my case, I found a huge change in the upper RPM curve shape when I went to the 3/8" double taper pushrods (which also netted about 6 hp). I have spoken to several engine builders and my experience is typical.
Guess my point is that these failures have several contributors and may not simply be the rocker itself.
