What am I forgetting
Old Jan 4, 2014 | 01:46 AM
Bad28's Avatar
Default What am I forgetting
Ok I have a 2000 z28 and in march I plan to upgrade it a little am I missing any parts that I will need or should get
I have so far polluter cam, ls7 lifters, comp 650 springs,push rods, 799 heads, trunion upgrade, headers, arp head and rod bolts 4:10 gears with locker and ls2 timing chain
To my knowledge all I have left to order is my monster clutch and an ls6 intake am I over looking anything
Old Jan 4, 2014 | 01:48 AM
Bad28's Avatar
Oh ya also have full umi sub frame connectors
jsteele90's Avatar
oil pump maybe. and im sure you will need to upgrade your fuel system as well.
Old Jan 4, 2014 | 01:52 AM
Bad28's Avatar
Ya I forgot I have 8.1 injectors my bad
Old Jan 4, 2014 | 02:04 AM
jsteele90's Avatar
look like a solid list. do u have all your gaskets, fluids, tools you will need?
Old Jan 4, 2014 | 02:10 AM
Bad28's Avatar
Ya I believe I do. Do you for see any issue?
Old Jan 4, 2014 | 02:21 AM
jsteele90's Avatar
well if you are pulling the heads off and replacing the lifters i would replace the trays as well.
Old Jan 4, 2014 | 03:08 AM
Bad28's Avatar
10/4 thanks man appreciate the input
Old Jan 4, 2014 | 07:21 AM
96capricemgr's Avatar
Are you doing ARP rodbolts in the car? Thought that was not recommended?
Old Jan 4, 2014 | 08:17 AM
Bad28's Avatar
I had planned on it I haven't heard anything about them being bad
Old Jan 4, 2014 | 09:55 AM
Well then you haven't actually researched it.
https://ls1tech.com/forums/generatio...oing-come.html
Katechs are designed to use near stock torque levels an are therefore less likely to cause this problem.
Pretty sure even ARP says you HAVE TO resize for their bolts.
Old Jan 4, 2014 | 10:25 AM
Bad28's Avatar
Wow that was for sure a very interesting read I've never even heard of that issue thank you for the heads up I may actually stay with the stock rod bolts any other advice?
