please help with compression ratio
Old Jan 6, 2014 | 08:08 PM
s10pro's Avatar
Default please help with compression ratio
I have a set of 243 if I was to put them on stock lq4 what would comp be at ?
Same heads on lq9 what would it be
Old Jan 6, 2014 | 08:58 PM
Burken01's Avatar
243 heads will put you at 10.40:1 CR assuming the piston is .007 out of the hole on average
Lq9 w/243 heads would be 11.17:1 CR estimate
