What size head gasket?
Old Jan 8, 2014 | 09:41 AM
ihdude's Avatar
Default What size head gasket?
Putting together a 408 build using 317 heads. What size bore of a head gasket should I run with this setup?
Old Jan 8, 2014 | 09:52 AM
Burken01's Avatar
Use the gasket that matches the size of the biggest bore of the 2 (head bore, cylinder bore)
Old Jan 8, 2014 | 05:21 PM
RezinTexas's Avatar
I would add ~0.020" to whichever is bigger - cylinder bore or head combustion chamber bore.
Old Jan 8, 2014 | 05:45 PM
Burken01's Avatar
Good call, cometic makes 4.030 bore gaskets in every thickness..
