Can someone run desktop dyno PLZ.
Old Jan 15, 2014 | 04:42 PM
rhino200099's Avatar
Default Can someone run desktop dyno PLZ.
wanting to see if someone can run desktop dyno 5 with my ls1 setup. looking to get 450-480 flywheel hp.
block
stock bore
stock pistons
stock stroke
stock crank
stock head gasket
heads
243 heads milled to 62.10cc
Intake
Lift 0.125" 83.2 cfm
0.250" 169.4 cfm
0.375" 226.8 cfm
0.500" 273.0 cfm
0.625" 287.4 cfm
0.700" 282.8 cfm
Exhaust
Lift 0.125" 78.6 cfm
0.250" 142.6 cfm
0.375" 172.1 cfm
0.500" 194.6 cfm
0.625" 210.9 cfm
0.700" 214.8 cfm
psi springs
130 lbs @ 1.800 installed height 370 lbs @ 1.175 open pressure Spring rate 384 lbs Coil Bind 1.100
stock valves and retainers
camshaft
Lift .598/.598
Duration @ .050 231/231
Lobe seperation 115
intake
stock ls1 intake
stock injectors
stock throttle body
exaust
1 7/8 long tube headers
if you need anymore information please let me know. thank you very much!
Old Jan 15, 2014 | 04:51 PM
old93camaro's Avatar
you send me your email addess an ill send the program to you..
