Aight wtf is this about?
Old May 12, 2004 | 08:20 PM
foff667's Avatar
LS1TECH Sponsor
Originally Posted by SilverSurfer
From reading through some of your other posts about the problem you're having I got the impression that although you're getting misfires on all 8 cylinders, on a couple of them the condition is more chronic. If that's not the case, then maybe the problem lies elsewhere. It could then possibly be that they didn't street tune the car as you said.
I don't think it's the fuel pump because if it was crapping out you'd be going really lean at WOT. But if somehow the fuel pressure regulator went bad the car might be getting too much fuel at idle and part throttle. Not a problem at WOT because the rich mixture could have been turned down, by lowering injector pulse width, at Cartek when it was tuned. Hook a fuel pressure gauge to the motor and see what's up.
Did you notice the stumble at part throttle when you first drove the car after it was tuned? If the problem wasn't there at first then try reseting the PCM/ECM by unplugging the big 50 amp fuse and the small 10 amp fuse in the 2 fuse blocks. After letting the car sit for a while plug them back in and re-Atap the car. If it's a sensor problem it might not come into effect right away. When I do this to my car the problem I'm having with the 3.96* of knock does not manifest itself for about an hour's worth of driving and I get normal timing. But then the computer learns and it goes back to limp home mode and 15* of timing. Easy to do and worth a try.
You said once you go WOT it takes a couple of seconds before the car starts to boogey. Are you able to power brake the car? Maybe the converter went bad or there's a problem in the tranny and it's locking up the converter at part throttle.
Make a list for us of the things you've done so far to try and troubleshoot the problem. Might shed some light for us.
i can stall it up just the same as before with no issue and i can check tcc slipage via autotap and nothing is out of the norm...the issue started im sure immidiatly after the tune but i was still kinda breakin the car in...and if you remember i had the issue with the car going directly to 3rd gear when id go wot...julio fixed that(missing parameter according to him) and i immidiatly noticed the stumble but didnt think much of it till i brought the car to the track the next night and it made it difficult to even turn the tires over going through the water...thats when i knew it needed to be fixed not to mention it bogging the crap out of the car off the line. As far as trouble shoot ive:
Replaced the wires(msd's) with new stock wires
Regapped the plugs from .055 to .040
Checked for spark on #1 cylinder
Checked plugs for rich condition
Fuel filter less than 8 months old
Old May 12, 2004 | 08:21 PM
foff667's Avatar
LS1TECH Sponsor
If the misfires are equally high on all cylinders also try borrowing a MAF T and leaning out the base idle, if the car is very rich at idle the plugs will load up.
dont know anyone local w/ maf t, but isnt that what i paid for when tuning? lol
Old May 13, 2004 | 07:16 AM
SilverSurfer's Avatar
I'm wondering if the tranny issue you had at first is completely fixed. Maybe the car's in 2nd gear when you're leaving the line or it goes into 2nd too soon at WOT. Could be some other parameters need attention.
What do your buds on NJfbody think? Any of them drive the car or ride in it? Maybe they could post and give us their input/observations.
When's Julio or Dave gonna look at the car? If it's not going to be in the very near future, then try borrowing a working stock/tuned PCM from a 98 car. As long as the car idles somewhat and drives with the stock PCM then you can test and see if the stumble/hesitation goes away.
Better yet, call up TSP and see if they can lend a hand. I'm sure they've got a real good tune for your setup already, maybe they can mail you a tuned PCM that you can swap in your car for test purposes. They seem to be very helpful and with you being a customer maybe they can do something for ya. Can't hurt to ask.
Old May 13, 2004 | 08:44 AM
foff667's Avatar
LS1TECH Sponsor
Thats one of the parameters i have set on my comp normally ie what gear im in...and thats all fine...I have to call up cartek today actually to set something up for early next week if possible...Ive pm'd jason for any tips for tuning this cam with no luck. As far as my friends go they all have mixed feelings on the issue, anywhere from "too much base timing" to "not enough fuel initially going wot" to "sounds like all your coil packs are going" to "its in the tune" so i dunno who knows what...cartek thought it was something simple like wires last time and otherwise i havent talked to them since, hopefully i can get something setup soon and get this taken care of so I can hit up MIR at the end of the month.
Old May 13, 2004 | 09:36 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Well if the car is rich at idle, it can load up the plugs and you can help fix this by leaning it out or burning it more efficiently. I would be more of a fan of leaning it out since that would improve fuel economy. MAF T is a quick way to check to see if it helps.
Old May 13, 2004 | 12:07 PM
OK. Here's a couple of things to do in the mean time. This is basic diagnosis but it might help rule out quite a few things that have been mentioned so far.
1. Hook a fuel pressure gauge to the car. I believe stock FP should be in the low to mid 50s. Someone correct me if I'm wrong.
2. Hook up a vaccum gauge to the car. You did experience a vaccum leak when you put the motor together. There may still be a slight leak somewhere that's going unnoticed. I won't venture to say how much vaccum you should be seeing, but I'm sure someone can shed some light. I figure at least 10 in/HG at idle.
3. Get/borrow/steal (lol) a timing light. Although pretty useless on our cars, it's still the easiest way to check for spark. Hook up the light to each plug wire one at a time and see if the light flashes. Check it at idle and 2-3000 rpm. If you know any mechanics and they can hook the car up to a scope, even better.
I believe these 3 things are very important for you to do.
Old May 14, 2004 | 08:29 PM
Off the topic, but the tranny is in aswell as the converter. When your car's fixed we'll play.
Old May 14, 2004 | 08:45 PM
foff667's Avatar
LS1TECH Sponsor
very kewl
