I need schooling on 5.3 blocks
Old Jan 20, 2014 | 08:16 AM
LS1HIGHLIFE's Avatar
Default I need schooling on 5.3 blocks
Speciffically iron 5.3s. Do they use the same mold as the LS1 or LS6? Same engine covers? Can they be bored and to what extent?
Old Jan 20, 2014 | 08:47 AM
conan's Avatar
The older gen 3 iron block 5.3L - LM7 are just about identical to the ls1/ls6 blocks. The alternator mounting is differant from iron to aluminum. The iron blocks are missing one of the threaded holes that the aluminum block uses for the mounting bracket. People have drilled and taped the the iron block to use the F-body alternator mount.
All the covers will bolt right on from the aluminum to iron, and you can bore the 5.3L out to a 5.7.
Old Jan 20, 2014 | 08:48 AM
KCS's Avatar
KCS
Moderator
Not exactly the same mold, slightly different, but everything swaps over. You can bore them out to 3.905" pretty safely.
Old Jan 20, 2014 | 09:31 AM
Thanks guys. What c.i. can be achieved with that 3.905 bore? How long of a stroke can these clear? What are the differences between it and the alinimum version?
Old Jan 20, 2014 | 10:12 AM
KCS's Avatar
KCS
Moderator
You can get 383ci with a 4" stroke, and 395ci with a 4.125" stroke. The 4.125" stroke crank can be tricky and can end up a disaster if not done properly, so I'd suggest a 4" stroke max.
The differences are basically cosmetic. The main saddles are beefier on the aluminum blocks since they're aluminum, and the big water plug is different. That's about it though.
Old Jan 20, 2014 | 10:29 AM
Sweet. What's the weight diff between the cast 5.3 and the LS1? FYI, the reason I'm interested is my stock LS1 block may have a couple of cracked slaves and I can get my hands on a iron 5.3. I wonder what the cost to resleve is vs boring and building a 5.3....
Old Jan 20, 2014 | 11:25 AM
conan's Avatar
Iron block is about 100#'s heavier than the aluminum block.
Old Jan 20, 2014 | 05:38 PM
RezinTexas's Avatar
It cost me $300 to bore and torque plate hone my 5.3 block 0.124" over to 3.903" bore. This was at HKE in Houston in 2011.
My advice is try to find a used 6.0 block before dropping that money on a 5.3 block. Everything that swaps over to the 5.3 block will also work with the 6.0 block. They are identical except for the bore size.
Old Jan 20, 2014 | 07:44 PM
Roger that! Just found out my block is good. That should buy me some time until I do a build. I may just pick this 5.3 up to slowly work on it over a couple of years.
I apreciate all the info gents.
Old Jan 21, 2014 | 06:47 AM
Paul Bell's Avatar
That's MISTER MODERATOR
More cubic inches = a better performing engine.
100 pounds off your front end = a better performing vehicle.
Why fool around with a small engine that's heavier?
