putting a build list together , help me out
Old Jan 20, 2014 | 08:45 AM
wavebyby's Avatar
Default putting a build list together , help me out
I have a 2000 m6 camaro ss , the car has bbk long tube headers , bbk ory , magna flow exhaust , slp lid with k&n filter , egr delete, and a hp tune ,
Im redoin my clutch , slave , master and all that goes with that ... Im also looking to do a h/c/i swap with a 75 -100 shot of nitrous .. Im looking to spend around $3500 maxx whats are my options
243 heads , ls6 intake , cam , nitrous
looking for to make a fun fast street car , and i dont drive it all the time what would you guys buy id like 450 + hp on motor and 500 on spray
Old Jan 20, 2014 | 10:15 AM
97camaro383's Avatar
Contact Martin @ Tick Performace, he'll help you pick a good setup.
The sns stage 2 or 3 cam would give you great power and still drive fine. You could also look at TSP stage 1 ls6 heads
Old Jan 20, 2014 | 10:52 AM
BigCityFire's Avatar
How much work are you willing to do yourself? You'll save THOUSANDS doing it on your own. If you pay someone else to do it you will hit that $3500 mark pretty quick! I did all my own engine work and I had little to no mechanical experience with engines. All it takes is time, patience, the brains on this forum, and the right tools. I went with 799 heads and a Brian Tooley Stage IV cam. Got the FAST 92 with a NW 92mm tb as well. Will be having it dynode and tuned sometime in February.
Old Jan 20, 2014 | 07:20 PM
garygnu's Avatar
consider Texas Speed ls6 st 1 heads with a torquer v3 cam .or use a ed curtis street sweeper cam.or look at a vengeance racing trick flow head/valve train pkg.you will need bigger injectors and a better fuel pump.you will need a tune .
Old Jan 20, 2014 | 11:28 PM
chevybayboy's Avatar
Don't for get the nitrous and the stuff you need to run it like blow down tub a way to pull timing different plugs... if you got 3500 to spend save an extra $500 for the unexpected things gaskets extra bolts and ect
Old Jan 20, 2014 | 11:29 PM
And your probably going to want to run bigger injectors
Old Jan 21, 2014 | 02:02 PM
wavebyby's Avatar
I have 42lbs injectors , and ill be doin the work my self ...
Old Jan 21, 2014 | 02:04 PM
wavebyby's Avatar
will $3500 get me to where i want to be , like i said i have the 42lbs injectors and ill be doin the work
Old Jan 21, 2014 | 02:07 PM
SStressin's Avatar
Ls6 inake 300 Monster stage 3 kit 830 Tsp cam kit 750 243 stock heads 450 Nitrous gonna cost you 650 for kit plus 550 for acc An add another few hundred for gaskets bolts etc
Add another 3 grand when you blow your 10bolt and driveshaft to pieces
Old Jan 21, 2014 | 02:12 PM
wavebyby's Avatar
sstressin u still looking for the ss rims and where on long island are u located
Old Jan 21, 2014 | 07:09 PM
inssanity21's Avatar
My "build" had me up to 6500 and it started with a plan like yours. It snowballed very quickly. I am now up to 9 and think I will be closer to 11 at the end of this coming season.
