Which oil pump for 383 stroker?
Old Jan 24, 2014 | 04:04 PM
SStressin's Avatar
Default Which oil pump for 383 stroker?
Had a gm high volume/high pressure pump that i got from katech. Deciding what i should do for my 383 stroker? Its an all out build callies/diamond , trickflows , huge cam etc. going to spin it to 7200. Should i get a 10295 , 10296 or keep this one? Or any other options?
Old Jan 24, 2014 | 04:17 PM
Gray86hatch's Avatar
Schumanns from car shop Inc.
Best stuff on the market.
Tim
Old Jan 26, 2014 | 08:41 AM
SStressin's Avatar
bump..... anyone else? whats your opinion on the current pump I have?
Old Jan 26, 2014 | 09:08 AM
v8pwr's Avatar
The pump that you have is a good pump. The Schumann's is the top of line while the others fall behind it. Ultimately your pump needs will be determined by your build's clearances. If you're engine isn't too loose that pump will fine for a performance stroker build.
Old Jan 26, 2014 | 11:07 AM
JakeFusion's Avatar
Super Hulk Smash
That pump will be fine.
