End gap
Old Jan 28, 2014 | 01:21 PM
cbenn47's Avatar
Default End gap
What is the norm for piston gap on a gen3 5.3, doing the math I take the bore 3.780 x .004 correct? So roughly .016 top ring then add 20%/30% so second ring .018, is this correct.
Going to be a DD blazer slight mods cam/ some head work and a ls6 intake other then that stock. So what do you LS guys recommend for ring gap, should I just go with what I listed above?
Any input would be appreciated.
Old Jan 28, 2014 | 08:42 PM
cbenn47's Avatar
Another part to the question is do you need to file if you purchased Hasting rings, was told by the parts person that they were manufactured to fit a standard bore and no filing required, just want to make sure I have the right gap prior to installing pistons, any help appreciated.
Old Jan 29, 2014 | 01:05 PM
baronsmith98's Avatar
Put a ring in the cylinder and use a piston to square it up about an inch below the deck surface. Then use a feeler gauge to measure the gap.
