Which cam
Old Jan 28, 2014 | 05:15 PM
sbf's Avatar
sbf
Default Which cam
I have a 98ls1 that's getting forged rods and pistons.tea ls6 stage 2 heads milled to 59cc 11.1cr.port matched fast 92mm intake 1-7/8 headers full 3in exhaust borla xr1 mufflers,4l60e circle d 5c stall 4.10 rear gear.putting this in a foxbody with race weight of 2950-3,000lb.not a daily driver but mabe 2times a week and sometimes track.i have a few cams in mind.i would love for the car to run mid to low 10s and mid to low 6s 1/8 mile on motor which cam would be my better choice,don't want a big donkey dick cam I think all of these should have good drivability.
1st-fti streetsweeper ht-228/232 111
2nd-fti hellraiser-229/236 111
3rd pred z el-toro 230/230 111
4th-eps 230/234 111
Old Jan 29, 2014 | 09:50 AM
sbf's Avatar
sbf
???? No one can help
Old Jan 29, 2014 | 10:18 AM
JakeFusion's Avatar
Super Hulk Smash
Of those, the Hellraiser will probably do what you want.
EPS lobes will be easier on the valvetrain and still make power.
Why not talk to Geoff @ EPS or Ed Curtis and get a custom spec?
Old Jan 29, 2014 | 01:38 PM
DACTARI's Avatar
+1 on the Hellraiser, though you could go bigger given how you plan to use it, the auto transmission and the low weight of the car. Look at the tick Stage 3 SNS for LS1: 235/243 111+3
Old Jan 29, 2014 | 01:42 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Good options.
I'd throw the original Street Sweeper in as well, or a tweaked version of it from Ed. You've got the gears for it no problem.
Old Jan 29, 2014 | 01:48 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
Have you considered a TorquerV2 (232/234 .595/.598) on a 113 LSA. Should make good low end and mid range without sacrificing drive-ability. Idle will be moderate but not crazy aggressive.
I even have some of those in stock that are on sale for $329.99!
Old Jan 29, 2014 | 03:38 PM
Cra-Z Larry's Avatar
With the setup you're running it's just begging for a big cam!! Put something in there that will take advantage of the compression, heads and converter you have! But that's just me, I like big converters and big cams!!
Old Jan 29, 2014 | 04:05 PM
99Bluz28's Avatar
Tick Street Heat Stage 2 (ls2 version). It'll have just a few more degrees of overlap than the EPS cam on your list which has 10*OL, but will favor the top end more.
http://www.tickperformance.com/tick-...r-ls2-engines/
For a slightly smaller /milder cam look at the Tick Street Heat Stage 2 (ls1 version).
http://www.tickperformance.com/tick-...1-ls6-engines/
Now, for the cams ONLY on your list, I'd go with #2nd-FTI Hellraiser-229/236 111, mainly because of the wider split.
 Michael S. Palmer
Old Jan 29, 2014 | 04:18 PM
sbf's Avatar
sbf
I no a big cam would make a lot of dyno power,but no usable power the cams I picked out I have seen them run 10.50-60 1/4 mile 33-3500lb vehicle and still daily drivable,I haven't seen bigger cams that do much better other than give up drivability
Old Jan 29, 2014 | 04:20 PM
sbf's Avatar
sbf
Dr whigham how did the hellraiser perform
Old Jan 29, 2014 | 04:25 PM
sbf's Avatar
sbf
I seen this cam work really well with prc 5.3 heads how well will it work with my heads
Old Jan 29, 2014 | 04:29 PM
Performs very well with Ported LS6 heads. We use the same cam in a lot of our Stage 2.5 LS6 heads/cam packages with great success!
Old Jan 29, 2014 | 04:37 PM
dr_whigham's Avatar
The Scammer Hammer
Awesome brother. I loved it. I had a stock 10 bolt with 3.42's, and it was still fun to drive. Upper RPM just wanted to pull and pull. Mine was ground on a 112+2 as well.
This is my sheet with AFR 205's (59cc) stock GM MLS gasket, Unported FAST 92/92, and an SLP lid. Stock 145k mile shortblock...
I was actually spec'd that cam as a cam only, and wound up piecing everything else together before it became install time. Ed said not to worry though, as more air in = more air out.
Old Jan 29, 2014 | 04:41 PM
sbf's Avatar
sbf
Did you ever get a time slip on it Ed actually to me it would work well with my set up all the cams were spec for my set up but trying to see which one is better
Old Jan 29, 2014 | 04:44 PM
sbf's Avatar
sbf
Also guys I'm not saying a bigger cam is out the question but I don't want a big cam that makes 5-10 or half a tenth faster than the ones I choose,Brian tooley also told me many people change cam chasing a dyno number and gets slower at the track,so I'm just a fan of small to mid size cams
Old Jan 29, 2014 | 04:48 PM
dr_whigham's Avatar
The Scammer Hammer
I never did, but Geoff was certain with the right suspension set-up (MADMAN) as well as slicks and skinnies, the car would have went high 10.70's all day
Old Jan 30, 2014 | 09:22 AM
Sales@Tick's Avatar
Look up Windmill on here.
I did his combination for him. He has a 2900lb. fox body with the simplest combo I feel I've ever done.
Stock bottom end LQ4
Stock 799 heads (10.3:1 compression)
Victor Junior
800 Carb
231/240 .617/.588 110lsa camshaft
Power glide with 5000 stall
4.56 gears
This car runs consistent 6.40's@106 with 1.4x 60's
It's been 5.90@115 with a 150 shot and a 1.32 60'.
You have a light car. You have compression and a big stall. There is no reason not to run a bigger cam.
I ran 239/247 110lsa cam in my stock bottom end 3000lb. F-body with the same 5C stall. It was loosened up to 5800rpm. With a 4.11 rear gear I was able to get it to go 6.38@105 CAM ONLY.
Stock 241 heads just like they came from GM. Fast 92 with a 92mm NW TB. 1x7/8" ARH headers. Extremely simple combo with way less compression than you have. I was using heads that are no where near the level of your heads either.
Just something to think about. I have personal experience with a light weight car, the exact same stall converter you're running and a much larger cam than you're contemplating. It's no coincidence at all as to why the combo I personally owned runs the times you're looking to run with a stock bottom end CAM ONLY.
At one point in time I was going to put CNC ported heads on my car, fly-cut the pistons and make a run for 5.90's but I put nitrous on it instead. I know it would have done it. I just needed more horsepower.
My times were also done off the foot brake. Here is bottom 6.40 pass:
Old Jan 30, 2014 | 10:16 AM
sbf's Avatar
sbf
Martin how was the drivability on the street
Old Jan 30, 2014 | 11:33 AM
Sales@Tick's Avatar
With an unlocked stall it was fine. With a locked stall converter that will change dramatically though.
IMO the 235/238 camshaft I recommended for you is perfect for your application.
Old Jan 31, 2014 | 03:13 PM
SNLPerformance's Avatar
What are you going to spin it to?
