Symptons of spun rod bearing??..??
anywayyy, i still took off the covers and checked the rockers and everything. The were all torqued to specs still. I drained the oil and i did notice some FINE flakes in it. BUT keep in mind i swapped heads about a year ago. We put dyno oil in there for the startup and break in, then replaced that with mobile 1. Thats the oil thats been i nthere since then. I dont drive the car to much, so i only put about 2-3k on her since then. Im just wondering of those flakes came from some shavings left in the heads maybe? I cut the filter open and no metal peices or anything, just a few little flakes again(nothing major). Car isnt making any weird sounds anymore so im hoping it was just the AIR leak cuase it sounded much like a lifter sticking or tapping.
I showed the oil to a mechainc i trust and he sdaid he didnt see anything strange. That must spun bearings would turn the oil goldish?
any ideas?? oil PSI is very good and no other sounds are coming from her. Im just being safe right now cause im paranoid its something major LOL
im just thinking those flakes came from some shavings outta the heads maybe which didnt all come out when we broke the heads in
anyone have pics of there oil when they spun a bearing maybe so i can look and see?
I thought the heads were cleaned well. After the startup and first break in that oil was drained and replaced with what i just drained out day.
Savage, this is one of the damn deals where you wish i would break you you definitly know wtf is bad lol. Even if it costs more, i'd rather fix it then wonder what is about to break or bad
Glen, i used a strainer when i drained the oil out. I caught a few peices of trash, but nothing metal wise. One peice of trash looked like a carbon build up almost.. see the last pic. The other stuff in the pic is what seems like some gasket material/sealant and the other actaully seems like a peice of the oil filter liner.
flakes on filter(posting link cause pics a little big for this screen/page)
http://www.callaocarcenter.com/metal.jpg
pic showing trash in the oil
The filter media looks from what I can make out, little shiny bits. Do they stick to a magnet? This is the second oil change since a rebuild or just a head swap? Did the heads get cleaned after recieving them and before install? Were the spring seats in the head enlarged? Did they reinstall the metal spring seat under the spring? But..... it could also be just debris from a bad cleaning job.
im gonna go out tomorrow and hammer the car... if she goes it goes.. nothing really I can do about it. If it holds, ill put another 100-200 miles on here and check the oil for this stuff again. If its there still, then i know I have isues I guess
Jake: that looks like what my guage does. I let off and it goes up.. give it a little and it comes back down but never below 40 usually.. at the lowest i see 38
did yours eventually just shut down? Or did you take her apart and look for a problem?
this sucks LOL
this sucks LOL
im probbaly over reacting so im hoping it was just a exhaust leaks and the debris I found was just left over flakes form the heads maybe
I did slack on the oil change, but I also havent exactly been hard on the car. I know that probably doesnt matter, but im pretty sure the oil was always good and filled. I check that everytime I go somewhere
LS1BLACK: my pressure is still good.. when she started betting below 30 on the gauge then ill definitly know somethings up
for now its 42+
