gen3 VS gen4 crank sensor?
I have an AEM EMS ECU. Already have the new 4x cam tooth and 58x crank tooth tune loaded in the ECU. that shouldn't be an issue. Just need to know If I can use my old gen3 crank pickup to read the 58x tooth crank trigger or not.
OHM'd the sensor s out and got 780 on one and 800 on the other. (mid pin to grnd)
Are all the sensors setup this way?
(sorry for large image)
Thanks
