Ported Heads - Thread locker or sealant?
Old Feb 9, 2014 | 02:16 PM
55chevy's Avatar
Default Ported Heads - Thread locker or sealant?
A couple of the ls1howto's mention using loctite on the rocker arm bolts but I've heard I should use sealant on them since I've got ported heads.
I can see that the rocker bolts travel through the head and into the edge of the intake ports so I'm pretty sure I need a good sealant.
I purchased Permatex "high temperature" thread sealant whichs shows up to 400 degrees F.
Old Feb 9, 2014 | 02:20 PM
brandon6.0's Avatar
Thats what i used.
Old Feb 9, 2014 | 02:23 PM
JakeFusion's Avatar
Super Hulk Smash
Blue Loctite. It seals the threads as well as keeps the rocker arm bolts from backing out (although, it's not super strong in that regard). Blue Loctite is good to about 300 degrees as well.
Old Feb 9, 2014 | 02:45 PM
conan's Avatar
I use the red hi-temp Permatex as well.
Old Feb 9, 2014 | 05:47 PM
KCS's Avatar
KCS
Moderator
Either will work fine. I've used both with success.
