Priming New Engine
Old Feb 11, 2014 | 01:15 PM
02BlkZ28's Avatar
Default Priming New Engine
Im sorry for a repeat thread, but i need help. I read one time before about someone using a insect sprayer from walmart to prime engine with. Can someone help me out with details of what exactly to buy & where to hook it up to on my block to prime bearings & lifters & all?
Old Feb 11, 2014 | 02:13 PM
mchicia1's Avatar
There should be assembly lube on everything, so it's not like it's going to be a dry start.
Just leave the plugs out and crank it over to prime and be done with it
Old Feb 11, 2014 | 02:32 PM
JakeFusion's Avatar
Super Hulk Smash
If you assembled with assembly lube you should be good. You'll build pressure almost instantly when it starts.
I just let the starter kick mine over in 3-5 second bursts to not destroy the starter and to prime the oil pump with the fuel injectors and ignition unplugged. It fired right up.
Old Feb 11, 2014 | 02:48 PM
ATK Engines's Avatar
This is a good way of doing it, its called a pre luber. A pressurized system which gets the oil throughout the engine/crevices. You can do it like others listed, but this is a reusable system and preferred method by most builders.
Old Feb 11, 2014 | 04:48 PM
v8pwr's Avatar
Look in the Tool section as someone showed a simple pump from Harbor Freight that pre lubed the engine easily and affordably.
