241 Heads vs. 317 castings
Old May 11, 2004 | 10:14 PM
70Chevelle's Avatar
Default 241 Heads vs. 317 castings
I am going to be building a shortblock so I will be able to use either head to reach my desired comp ratio but which head will perform better? Which head flows more?
Old May 11, 2004 | 11:02 PM
JZ'sTA's Avatar
The 317 will flow better stock for stock and ported for ported in most lift ranges.
Do a search it will help. The button is very good to use.
Old May 12, 2004 | 12:14 AM
jrp's Avatar
jrp
SN95 Director
whats your desired compression. theres about a 4cc difference between the heads.
Old May 12, 2004 | 08:50 PM
ROCNDAV's Avatar
The 241 is your basic 99+ LS1 Head. The 317 head flows more and lowers the compression. The 317, 243 & 035 heads flow the same. The 035 is a die cast where the 317 is a sand cast (with the die cast being a better casting type). The 243 head is the LS6 head.
I'm not sure how to post a picture, hopefully I can do it right
ROCNDAV
Attached Thumbnails 241 Heads vs. 317 castings-ls1headinfo.jpg   241 Heads vs. 317 castings-ls1headinfo.gif
