LT1 block ???
IS THIS BLOCK FOREVER DEFECTED DUE TO THE SPUN BEARING EVEN IF NEW BEARINGS ARE INSTALLED????
the reason why i ask is becouse i have noticed blocks advertised for sale saying that its never had a spun baring b4. thanks, marcus
as long as the blocks not cracked, which it shouldnt be just from a spun bearing, it should be find for boring and stroking, just have it bored and honed, checked out, all the usual stuff that en engine builder does, how much does the person want for the block, if its just a block you shouldnt have to pay any more than about 150 bux for it
brian
brian
Have 4-bolt splayed caps installed and an align bore done and everything will be much stronger than the stock setup. Its not cheap to do, but IMO worth it if you put any kind of power through it, last one I did was almost $400 extra for the 4-bolt caps including the machine work. If it had a main bearing spun, that was probably a factory machining error with that low of mileage. LT1 bare blocks can go anywhere from $200-$450 depending on what needs to be done to them.
