LQ4 crank in LS2 block?
Old Feb 21, 2014 | 12:04 AM
Iwannagofaster's Avatar
Default LQ4 crank in LS2 block?
I've been searching for an iron 6.0 to start my build, planning on stock crank with forged rods/pistons. I came across a ls2 block at a local machine shop for 400 that has already been honed and cleaned up. Would there be any issues using a crank from the lq4 in this block? Also wondering if they would use the same rod and piston combos i've been looking at.
Old Feb 21, 2014 | 12:10 AM
KCS's Avatar
KCS
Moderator
Should be just fine, just have the clearances checked and the crank may need to be balanced.
Old Feb 21, 2014 | 12:18 AM
That's what I wanted to hear, thank you fellas
