lifter preload
IM using ls7 lifters, 7.375 pushrods and stock rockers, on average, once I established Tdc and zero lash, it took 1&3/4 turns to reach 22 ft/lbs. Some rockers took a little more, some a little less.
Vettenut's calculation differs from the linear .047 method in two respects. One is Vettenut's recognition that 1/3 turn is associated with bolt stretch as opposed to preload. JakeFusion, based this and other threads (https://ls1tech.com/forums/showthrea...544&styleid=25) apparently agrees with Vettenuts on this fact. The second difference in Vettenut's calculation of preload that differs from the linear 0.047 method, is its recognition of the rocker ratio 2.7/1.7. I cannot tell whether JakeFusion agrees or disagrees with this aspect of Vettenut's calculation. In any event, the three methods would put the 1 3/4-turn preload at 0.0823, 0.1110, or 0.0667 inch depending upon one's point of view.
The good news is, everyone seems to agree that 1 3/4 turns is acceptable.
Stock LS2 rockers/ stands/ valves
Stock LSA pushrods
LS7 lifters
Comp Cams 54-426-11; 222/224 Duration @ .050, .566 /.568 Lift, 112 LS
Felpro MLS
I was measuring:
.085" preload on the first turn,
.112" just as trunion bottoms out (snug before torquing) at a bit less than 1.5 turns,
.115" when torqued to 22ft-lb - at 1.6 turns.
All 16 were in the range of 1.5 to 1.6 turns.
I find this is fairly close to the center of lifter plunger travel as there was another .099" of available displacement.
All according to the dial indicator probe located on the rocker adjacent to the oil hole - not ideal as there is some monkey motion as the rocker pivots off the valve as its pulled down to the stand.
Regards
mk
this counting turns business is about as precise as using a shotgun to open a bottle of beer.
I can't measure lifter preload with pushrod checker and calipers, once I have the "correct" length pushrods installed and wish to final check the assembly. I need to measure the lifter plunger displacement. The best I can do is measure the rocker displacement "as close to" the pushrod as possible. All I am trying to share is that the "count the trunnion bolt turns" was in strong correllation to that rocker displacement measurement - sample size = 16, so was just adding to the forum sample size.
All 16 were in the range of .100" ~ .115" measured at the rocker.
I guess for a correlation I really should have documented the degress of rotation Vs displacement for each valve - and paired up those #s statiscally, but I stumbled on this thread after I assembled the valvetrain.
This 'counting turns business' goes way back - it procedural on adjustable rocker hydraulic lifter engines like old school SBC's.
CK - how are you measuring the lifter plunger displacement?
mk
mk
The moral of the story is that if you measure your zero-lash lengths accurately with calipers, your actual preload will be pretty much dead nuts on to your theoretical values by +/- 0.001", depending of course on the manufacturing tolerances the machinist is able to hit. No guessing involved.
