Speed engineering camshafts
Old Feb 24, 2014 | 11:54 PM
possessedsaint's Avatar
Default Speed engineering camshafts
Any reviews? Opinions?
I know their race headers have gotten really good reviews..... What about cams
Old Feb 26, 2014 | 11:30 PM
anybody install this?
175 views ....i know someone has experience with his cams
Old Feb 27, 2014 | 07:36 PM
bump it!
Old Feb 27, 2014 | 07:39 PM
HCI2000SS's Avatar
Never heard of them. How many different grinds do they carry? Are they all LS specific?
Old Feb 27, 2014 | 07:45 PM
JakeFusion's Avatar
Super Hulk Smash
Looks like every other Comp XE-R grind ever made.
Old Feb 28, 2014 | 12:08 AM
03EBZ06's Avatar
Well, pretty cool they make their own headers, but didn't see any of their own cams.
I noticed they had no grinds of their own, which means they may not test any. I mean to have credentials, you need to steal a comp cam lobe and rename it to something of your own liking, like:
POWAH CAM STAGE 3 ( 10 deg ground in advance 198/269 @ 0.050", was the daddy of the LSK lobes; makes power all the way to 20,000rpm with right components. 2 story Holley intake required)
FCKING AH STAGE 1
FORD AZZ REEMER 6
WHATHEFK DID I CREATE STAGE II
DONKAZILLA
FUCKSTICK8
MAGIC CAM #3
MOMBADONGA EXTREME RACE ALL OUT STAGE 7 CAM (with and without .900 lift springs for your stock ls1 heads; come with ls6 generic springs that have their own name but made by someone else also)
You get the idea. A little humor for the masses out there.
Old Feb 28, 2014 | 02:34 PM
http://www.speedengineeringlsx.com/2...-ls6-camshafts
is this not their own camshafts?
if not who makes it
Old Feb 28, 2014 | 02:46 PM
03EBZ06's Avatar
if not who makes it
Ah ok I see they gave a few they use. Didn't see them on site before . Those are comp cams and they don't grind them themselves. First one I saw an xer lobe.
It's really a matter of what is your combo? Then select
 Michael S. Palmer
Old Feb 28, 2014 | 02:49 PM
03Sssnake's Avatar
They are rifle drilled, not solid core, so Cam Motion did NOT grind them... I am with jake, just a glance at the specs and I would be willing to wager they are a Comp Grind...
Old Feb 28, 2014 | 04:43 PM
so they are reputable cams
Old Feb 28, 2014 | 04:47 PM
03EBZ06's Avatar
Comp makes excellent cams and they perform well also.
Old Mar 2, 2014 | 07:27 PM
cool....well i guess i will have to decide on certain heads.......then get a cam based off that...maybe a custom grind depending on the flow
