Will they fit?
Old Feb 27, 2014 | 07:55 PM
Ls_Notch's Avatar
Default Will they fit?
I've got a set of prc stage 3 243s with the 2.08/1.60 valves, will they clear on a stock bore 5.3?
Old Feb 28, 2014 | 10:26 AM
joshua022's Avatar
They will, but your compression will drop some due to the larger combustion chambers, unless they've been milled.
Old Feb 28, 2014 | 11:58 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Those heads are designed for a 4.03" bore. In a 5.3 application the valves would be severely shrouded. Also, I haven't checked myself, but I would question whether or not the valve would even clear the bore. I would choose a different head myself.
Lonnie
Old Feb 28, 2014 | 05:41 PM
redtan's Avatar
I always heard that a 2.02-2.04 is the MAX you can safely put on a 3.898 bore. On a significantly smaller 5.3 bore there's not way a 2.08 would fit.
Old Mar 2, 2014 | 10:26 AM
A.R. Shale Targa's Avatar
3.78-(2.08+1.6)=0.100.....TERRIBLE
Some 5.3 blocks can be bored out to 3.898-3.905 range; however MOST engine guys prefer to not go any larger than 2.04-2.055 sized intake valves even on the LS1 sized bore.
Different heads is probably your best option in all honesty.
