No PTV clearance on LQ4?
Called Comp 3 times and basically they only said I must have something wrong cuz there shouldn't be any PTVC problems blah blah blah....... well its hard to ignore numbers
Anyway, we'll see I guess
Why? Although the pistons are dished and with the larger chamber heads DO have lower compression...the DISH itself does not extend all the way across the top of the piston.
Radial clearance is the issue here. you have plenty directly under the valve because of the dish...it's the edges of the valve that are coming too close...
FWIW my combo MAY end up being TEA CNC 241's and a martin cam on a LQ4 shortblock. I don't ANTICIPATE any PTV issues but you can be damn sure i'll be checking to be safe.
