WS6 - Engine Tapping Ticking Noise Only When Warm
Upon the first start up and a couple short test runs the car ran smooth and quite just as it did before the oil pump failure.
This morning after leaving the house and hopping on the interstate for the first time I noticed a ticking noise that was not present when cold and warming up and didn't start until after running fine for about 5 minutes and fully warm apx. 210 deg. The engine started making a noise of all of a sudden and grew louder till it was clearly audible inside the car and over the sound of the performance exhaust. The sound was very similar to a loud exhaust leak tick and clearly increased with engine speed. I did not however rev it about 3500 rpm for obvious reasons although there was no noticeable power loss.
I pulled over popped the hood and tried to pin point the location the sound was coming from. My best guess was somewhere near the intake manifold near the driver side valvecover. It did not sound like it was coming from the exhaust manifold. I killed the engine checked the oil level which was full. and let it sit for about 2-3 minutes. I restarted the engine and the sound was GONE!. It was completely gone. I started driving it back to house and after a minute or two the sound came back. I drove the rest of the way home apx. 5 miles and parked it.
Any ides what this could be? My first guess is maybe a faulty lifter but I am really not sure. Hopefully someone here can help point me i the right direction.
The car has about 130K miles on it and is all stock internally except for the new SLP oil pump & double roller timing chain I just installed. It has been well cared for and we have owned it since we bought it with 40k miles in 05.
I tried searching on the forum and cant find a logical answer. The engine does not normally make much noise at idle and if it did you couldn't hear it above the exhaust. I have ruled out the typical noisy ls1 piston slap stuff. This is a new mechanical problem of some sort.
Any insight would be greatly appreciated.
Thanks.
What weight oil are you using? Could be a collapse Lifter but sounds like it could be more like a pinched oring in the oil pump And sucking in some air[/QUOTE]
Why dont you pointlessly quote more dick massive brain guy who is smart?
I just hope we start seeing less galled pistons.
I don't know whatever happened to the OP. But he said after holding it a 3,000 rpm for several minutes he had issues. Well I've been in the same boat. My solution? To hold it a 5,500 rpm for about 35 minutes. Just lets her sing all of her problems out in the driveway. If that doesn't work try holdin it against the limiter for 15-20. She'll clear up.
I scare me. Jesus.
Hunting this down is driving me crazy!
