Loss of power after new intake
Thanks, ya'll are usually great with the responses!
You can test it out by taking the battery off, putting the old setup back on it, and trying it out. taking the batt of is the important part as it will reset the fuel trims.
Or you can leave the new setup on and take the batt off and see if it is good for just a little bit again. If so, you will need to either put the stock setup back on or get a tune.
Also make sure the arrow on the maf is pointed the right direction.
If you have the filter directly on the MAF itself, you can cause all sorts of other/airflow issues.
