ls1 wont start
Old Mar 14, 2014 | 09:03 AM
Josh Hopkins's Avatar
Default ls1 wont start
It seems as if we are out of ideas we rebuilt the trans on an 01 camero car cranks but has no injector pulse we have changed computers, crank sensor double checked pins in the trans and the plug disabled security rewritten the tune
It will start on ether but after a revolution or two it kills spark it seems
Old Mar 14, 2014 | 09:16 AM
Old Geezer's Avatar
Try the diagnostic/tune forum..........
Old Mar 14, 2014 | 09:44 PM
gMAG's Avatar
It is possible that the anti-theft is really not turned off, even though the steps you took, to do so, should have accomplished this.
Had the car been sitting, unused, for any length of time? If so, maybe the injectors are clogged.
Are you not getting any fuel?....or are the injectors really not "firing"?
Have the injectors actually been checked with a noid lamp, for pulsing?
If wires were moved, you may have broken the crank signal lead (yellow wire-1998...in the vicinity of the trans). This happened to me. I couldn't locate the break in the wire, so a bypass was run to the correct pin @ the ECM, and also to the crank sensor.
I can't recall if this signal is also responsible for spark. You mentioned that ether made the car run, briefly.
Old Mar 17, 2014 | 09:57 PM
bigfatls6's Avatar
Check the grounds on the back of the motor. SHouldn't have had to pull them to swap a transmission but myabe?
