Electrical problems after head swap?
Old Mar 16, 2014 | 03:52 PM
paladineWS6's Avatar
Default Electrical problems after head swap?
Goodday everyone! I was wondering what could cause electrical problems after a my heads were redone. Im guessing a pinched wire or bad ground? Based on these following codes could it be a bad pcm or ground? I couldn't find a unhooked ground theres some I can feel behind both heads the one by the battery one by the strut mount ontop so I dont know maybe its the one behind the intake mani? If its a wire maybe the codes have something in common that can help someone guide me in the right direction of finding the shorted wire? I will check the pcm tomorrow for broken pins and spray it with MAF cleaner anyways thanks alot!!!
Old Mar 16, 2014 | 03:55 PM
Oh yeah my AC stopped working a couple of days after this and my fog lights dont work I switched the relay and they work then I guess it pops the relay also a couple days after I got my car back the AC stopped so I bought the refil and the AC isnt vacuuming so the clutch isnt engaging? I changed the relay and nothing I might try changing fuse 24 and check the compressors connection thanks!!
Old Mar 16, 2014 | 08:00 PM
I guess im going to take it to an auto electrician monday ill let you guys know what they find
Old Mar 16, 2014 | 11:53 PM
4wheels's Avatar
Default Grounds
Could be a loose or missing ground strap from the cylinder head to the vehicle. That can impact the ground reference for a lot of the ECM/PCM related sensors.
Old Mar 17, 2014 | 12:00 AM
I put my hand in the back of the driver side head and felt the ground there maybe its loose? Ill try to tighten it but its gonna be a pita lol
Old Mar 22, 2014 | 04:36 PM
Could this be the problem?
