heads/cam OR procharger?
A procharger does seem to fit what you want, and we can likely get you the best prices on them.
Let us know if we can help!
I would recommend that you save your money, sell your car and pick up a used Z06. When you increase a car's horsepower by 50%+ reliability and maintenace (considering changing broken parts is maintenance) are a gamble. If you want to keep your car, I would go consider one of the huron speed turbo kits. If you want to go the heads and cam route, I would talk to AI, they can get you into a cam that will make good power, be streetable and have lobes that are easy on the springs so you won't have to change them often. I have a cam only car, if I had to do it over again, I would've went turbo.
I'd go with a somewhat small cam, like a 224/228 113lsa +4 (0* overlap) with some fairly mild lobes with no more than .600" lift, and a nice set of aftermarket CNC heads with 60cc chambers and stock thickness head gaskets.
I also liked the idea of a used Z06. I did look at those and they are still around the 40K+ price point, unless you get a higher mileage one. I know I can get a very nice, fairly low mile F-body for 15K plus ~ 5K for a H/C setup.
