LQ9 Swap-Need Help
CNC Ported L92 Heads
Hollow Valves
Holley Hi-Ram Intake
BBK Power-Plus 102mm TB
Kooks LT Headers
Random Technology Cats
True Duals with X-Pipe
Granatelli Plug Wires
Then when its all said and done, a custom tune.
I need some help on choosing my Cam (also components associated with a cam ex. springs, rockers, pushrods, lifters) mufflers, stall converter, fuel injectors and new gears
No towing, if any would just be jetski, four wheeler, that kinda thing. I want it as a daily that hauls ***. Need reasonable gas mileage, but want to be able to race ever now and then. Also mudding occasionally
Also, wanting to get a 2" leveling kit with 33's if that helps.
Hollow Valves
Kooks LT Headers
We are dealers for PTC and FTI converters and could help match a stall converter and camshaft for your combination and intended usage. We're also dealers for FIC(fuel injector connection) and Fast so injectors could be taken care of as well. We like to use Spin Tech mufflers as they have a lot of different options and great sound/flow for the intended application. Gears can also be taken care of as well.
I'd be glad to help you with a recommendation if you'd like one.
