piston rings..
Old Apr 3, 2014 | 01:56 PM
xdanny510x's Avatar
Default piston rings..
What are the best ones out there or what are most of yall using..im planning to refresh my block and upgrading my rings..
Been hearing.good things about hellsfire ..
I would be needing some that would.be suitable for a 200 to 250 shot
Old Apr 3, 2014 | 02:07 PM
ATK Engines's Avatar
Hellfire rings are a great ring, but they are moreso a drag engine ring...they are not as forgiving for street/strip cars as the Total Seal CP AP Rings package or Wiseco GFX. The hellfire rings will wear out the cylinder quicker.
Old Apr 3, 2014 | 02:09 PM
JakeFusion's Avatar
Super Hulk Smash
Agreed. Total Seal are probably the best you can run for nitrous/boost.
Old Apr 3, 2014 | 06:16 PM
COSPEED2's Avatar
LS1Tech Sponsor
Ray Ackerly has so many different setups to choose from. Usually with your setup (200+ nitrous) you would look at a steel top and I would recommend the HTD second and a std tension oil ring.
