heads and cam thoughts
Old Apr 4, 2014 | 08:14 AM
wilkes02SS's Avatar
Default heads and cam thoughts
here is my current build. I am looking to go to bigger heads, Maybe Mast and a lingenfelter gt-21 cam. wanting to see what everyone's thoughts are on the heads to support the cam
434 Cubic Inch LS6- Darton Wet Sleeve
Cartek Stage 5 Heads- 265 CC- 2.25 Intake/1.7 exhaust CNC Ported
W/ Ferrea Hollow Stem Steel Intake/ Sodium filled exhaust/ Comp Cams- 236/259 & 623/623 in @ 112 LSA
Wiseco 4.155 inch pistons = 11.5:1 Compression
Eagle Crank 4 inch Stroke/ H beam Rods 6.125 inch
2 Gallon A.R.E. 3 Stage Dry Sump- Stainless Lines to everything
A/N Fittings for Everything
Runs on a fixed speed density tune not MAF
Intake:
Fast 102 intake/ TPIS 90 MM TB
Carbon coupler
Vararam Ram Induction System
