ls1 12562174
Old Apr 5, 2014 | 11:16 AM
bigdaddyfuselier's Avatar
Default ls1 12562174
I both a ls1 engine from a local machine shop. i was told it was 2001 camaro.
When I looked up the block # it's a 1998 Is the right? they also put 706 heads on there. Will this set up work with ls6 intake? not sure on cam. Should i sale it
or put 243 heads and run it like that. I was looking to make 350 to 400 hp.
Old Apr 5, 2014 | 12:18 PM
96capricemgr's Avatar
706s will work fine with an LS6 intake and with your modest HP goal all you should need is a cam and supporting mods. 243s would make more power but are not needed for the modest goal.
Old Apr 6, 2014 | 06:59 PM
thanks
