408 questions
Old Apr 8, 2014 | 08:33 AM
VandykeT/A's Avatar
Default 408 questions
I'm putting a 408 together and had a few questions. The block I have is casting 12577184 and is a LQ4. What exactly needs to be done other than a .030 bore to fit the 408 rotating assembly. Any grinding for rod clearance etc. Is their a difference in the blocks LQ4 to LQ9. Is one casting better than another etc. It'll probably never see more than a 200 shot if that. Thanks
Old Apr 8, 2014 | 08:37 AM
pursuit2550's Avatar
I dont think there is much of a diff from the lq4 and lq9. I know my 06 silverado ss had the lq9 and the older 03-05 I think had the lq4
Old Apr 8, 2014 | 06:23 PM
RezinTexas's Avatar
should not have to grind block for 4" crank. although it is prudent to check. My 4" crank had ~0.070" clearance from the rod bolts to the lower cylinder sleeves.
