Fast 102 manifold clearance issues (LS6)
BUT
After following all instructions (including replacing the valley cover bolts with the lower profile bolts in the Fast assembly kit), I still get a wicked gap between the intake ports on the heads (Trickflow 220's) and the manifold. I pulled the 102 off of the car and inspected the area, trying to find the cause of the problem. It appears the washers in the ARP head bolt kit I used may be the culprit (See attached image).
Anyone else run into similar problems? Am I going to have to dremel out a notch for each washer? Or have i completely overlooked something simple?
Any/all help is always greatly appreciated.
