vid of engine noise - what is it? lifters?
while driving it and coming to a stop light, i heard a loud tapping sound that seemed to go away. i parked it less than 1/2 mile later at home. started it up the next day and after a few minutes it made the same loud tapping sound and shut it off. i tried again letting it idle for 5+ minutes twice, but it wouldn't reproduce the sound.
but valvetrain seems to sound louder with a tapping noise. i took a video and i think the phone cam is picking up the sound pretty good - can't hear it too good over all the other noise in person though.
what does it sound like to you?
edit: new vid very short. can hear it distinctly 4 seconds in. it sounds like it is coming out of the block and it does not sound good.
Step 1 would be to do an oil change and run the oil through a cheese cloth or one of those paint filters you get from the auto parts store to check for filings.
Step 2 would be to remove valve covers, check the rockers and check all the pushrods make sure the caps are on the sides and there is no up down movement of the pushrods like in a collapsed lifter.
I think you may find your cause on step 1 though.
this was the sound i heard initially when i decided to stop driving it. any ideas on what that could be?
still think its a rod bearing?
Problems not going away while the car just sits there.
I was busy working out of state and the car is my lowest priority. When I was home, I was more concerned that all the dust on it would make the hoa think the car wasn't running and so I'd clean it and let it idle. I have two other cars that were made in the current decade. If I didn't have the extra cash lying around I would have just let it sit until next year.
They were thinking it was nitrous going lean in that cylinder years ago and the problem just surfaced now, but I'm not sure
injectors
i just got the injector service report and they did mark the injectors before sending them out. at 3 bar, #7 had a less than decent spray pattern and was only flowing 63.5ml whereas the others were flowing around 84.5ml.
also.. it looks like a small chunk of the intermediate piston ring is embedded onto the top of the piston
Its very common for broken pieces to get back into the intake then if its not cleaned out destroy the repaired engine. Another important place to remove any broken pieces is from the exhaust. Yes its very possible to drag back broken pieces from the exhaust too.
I would carefully remove the broken pieces imbedded in the top of the piston and examine them closely to see what they are and where they came from.
Just my opinion... or just trust your engine builder because I'm just some guy on the internet suggesting you dig deeper.
