Heads and cam install tips/tricks
Old Apr 14, 2014 | 07:44 AM
ragtopz28's Avatar
Default Heads and cam install tips/tricks
Car in sig is ready for the transplant!
I have the heads w/correct springs already installed.
BTR cam, install kit w/all the gaskets, bolts, etc.
I guess I am looking for input on BEST write-up to follow and any tips/tricks, don't do's, s#*t I screwed up, etc. to make it go smoothly as possible. Thanks in advance.
Old Apr 14, 2014 | 09:31 AM
VandykeT/A's Avatar
LS1howto
Old Apr 14, 2014 | 09:38 AM
WS6ICK2k's Avatar
Originally Posted by VandykeT/A
LS1howto
+1 there is a few things that are outdated on there but for the most part is really accurate.
If I remember correctly just don't use the factory bolt to reinstall the balancer there are better ways without having all the force on the first few initial threads. I know a lot of people striped the threads in their cranks by following the how to word for word.
Old Apr 14, 2014 | 09:57 AM
ragtopz28's Avatar
THIS is what I'm looking for...keep em coming..Thanks,
Old Apr 14, 2014 | 10:08 AM
DANOZ28's Avatar
you need a new balancer bolt (only $5) , the issue i had was with the small and i mean tiny wire coming off the back of the intake sensor to the computer broke. cost me $100 to diagnose & repair. cheers!
Old Apr 14, 2014 | 11:01 AM
ragtopz28's Avatar
I have a new balancer bolt. I guess the lesson is go SLOOW. I know there is a vulnerable oil pressure sensor and cam sensor back there too!!
Old Apr 14, 2014 | 02:58 PM
BrntWS6's Avatar
Autozone was my friend for renting tools I didn't have like a in/lb torque wrench and pulley puller. I used a threaded rod with washers to push the crank pulley back on. Get a push rod checker. Change the oil again after your first test drive, it will be watered down from all the coolant that found it's way in there.
Old Apr 16, 2014 | 10:15 AM
ragtopz28's Avatar
Anyone else...I know some of you guy just did this..
Old Apr 16, 2014 | 11:57 AM
Blackpanther99's Avatar
x2 on LS1howto great tips.
Old Apr 16, 2014 | 11:59 AM
Baconz28's Avatar
Thinks it's some videos on YouTube.
Old Apr 16, 2014 | 12:42 PM
WS6ICK2k's Avatar
Ask and you shall receive I started a similar thread in the past goodluck.
https://ls1tech.com/forums/showthrea...471&styleid=27
Old Apr 16, 2014 | 01:15 PM
ragtopz28's Avatar
I have a 2-post lift at my house...should I do it that way? Easier?
Old Apr 30, 2014 | 06:28 PM
ragtopz28's Avatar
Bringing this back up for update and more advice.
The BTR cam I got would have had p/v issues with the milled heads I have.
They are swapping it out for me
Any more advice on tear down/install? Thinking about dropping motor out bottom since I have a 2-post in my shop.........
Old Apr 30, 2014 | 08:49 PM
tug686spd's Avatar
If you have a 2 post lift. I would keep the cam you have now drop motor out the bottom and get to experience fly cutting also. And it is a lot easier on your back and legs if your not bending and leaning over the fenders or nose of the car turning wrenches for a couple days.
Old May 2, 2014 | 11:56 AM
CHEVELLEPOSSE's Avatar
X2 on ls1howto
Old May 2, 2014 | 12:25 PM
TXZ28LS1's Avatar
Im gonna try and install heads and cam on my own.. but im scared to F something up.
Old May 2, 2014 | 01:57 PM
MikeZ28TA's Avatar
After you install the new springs do you have to check the height? is that required? sorry to hijack.
Old May 2, 2014 | 02:34 PM
BrntWS6's Avatar
I had never taken an automotive class in my life and I did just fine. Matter of fact until I did H/C i didn't know **** about cars....not that I really do now but I at least have a better understanding of how everything works. Being mechanically inclined, organized and following instructions are the important parts.
Old May 4, 2014 | 12:34 AM
WS6ICK2k's Avatar
Yea man if you have a 2 post lift I will def drop it out the bottom to do h/c/I. Will hanzels book ls1 how to covers step by step pic by pic which I found very useful. Like you mentioned earlier organization is def important. What I lack in mechanical ability I make up for with taking my time, research and paying attention on where everything goes haha
Old May 4, 2014 | 02:10 PM
Rare96LT1Formula's Avatar
The best advise I could give you would be to have the camshaft degreed in. Having such a crucial engine/valvetrain item NOT installed precisely is asking for trouble imho.
