c5z LS6 cam swap time
Old Apr 16, 2014 | 10:05 PM
93civEJ1's Avatar
Default c5z LS6 cam swap time
Ok, so I know this gets beat to death .
It has come time that I want to install a cam in my semi new to me c5z. It has 139k on it, but runs great. Engine is all stock to my knowledge inside.
I have my cam here already. It was a Brian Tooley custom cam 238/242 615/610 113+2 cam
I just ordered a set of Brian Tooley platinum dual spring kit. so that should cover my springs/retainers/seals and locks
I know I will need pushrods, but I am going to measure for those...im sure ill prob need stock size.
Besides that, what is REQUIRED for me to complete the install? I know replace the gaskets I take off. (so timing cover, pump gaskets, etc)
I see people mention replacing the crank bolt....with what?
I see people mention doing oil pumps or LS6 pumps...ok I have a LS6, do I really need to do a ported or high flow melling, katech, etc? Is it a must?
Timing chain stuff? A must? if so, then what
What else am I missing that is REQUIRED only. At this time im not looking to go all out...I may rebuild one day, or heck who knows have a diff car since i change so much.
So what is needed to just swap the cam on the car and get it going in a reliable manner?
Old Apr 16, 2014 | 10:19 PM
A.R. Shale Targa's Avatar
Oil pump is just a piece of mind thing since yours has 139 on it. Get a new pickup o-ring and at least a LS2 chain for 40 bucks. It's thicker/stronger and still uses your factory gears. You can get another GM balancer bolt since the original one is a torque to yield and has to be pitched. A reusable ARP bolt is about 35 as opposed to 10 for the stock 1 time use piece. Definitely measure for the push rods and I wouldn't be surprised if you need 7.425".
Tooley can get you all that's left for your swap and good luck to you.
Old Apr 17, 2014 | 12:18 PM
93civEJ1's Avatar
Yeah...so which oil pump is a good one for someone on a tight budget for now?
LS2 chain..ok ill grab one of those...ok to skip the C5R chain?
For the balancer bolt...I was thinking people mentioned getting a longer one? am I wrong?
Old Apr 17, 2014 | 12:47 PM
flattusmaximus78's Avatar
Another ls6 will suffice.
Old Apr 17, 2014 | 08:01 PM
The C5R chain is badass but most people put that on new gears..which then adds up to a few hundred bucks.
Another LS6 pump or IIRC the Melling high pressure/stock volume is a decent/cheap pump.
Lastly most people use a longer bolt to draw the balancer on the crank as a generic installer. Then back it out before it bottoms out and install a new GM
I just preheated my balancer to expand it, tapped it on a bit with a lead shot hammer, and drew it on the rest of the way with the new GM bolt.
Old Apr 17, 2014 | 08:26 PM
93civEJ1's Avatar
Ah gotcha...yeah I gotta start finding some tools I need such as the valve spring compressors (wanna use those that do 2 at once), and a pushrod length checker.
Old Apr 18, 2014 | 01:28 PM
93civEJ1's Avatar
ok...I am thinking of starting to tear it down tonight. Any things I should look for or keep in mind while doing this? Certain tools I need to get i have most of the basic tools, but anything special??
