trick flow valve spring problems
Old Apr 22, 2014 | 02:51 PM
986.0ta's Avatar
Default trick flow valve spring problems
Has anyone had a issue with tfs valve springs I keep breaking them I have a ms4 and springs are rated to 660
Old Apr 22, 2014 | 02:56 PM
LS1MCSS's Avatar
What is the lift of that cam, and have you checked for coil bind with the springs?
Old Apr 22, 2014 | 05:28 PM
Brian Tooley Racing's Avatar
When were the heads purchased?
LSK lobes are hard on springs.
Old Apr 22, 2014 | 06:07 PM
986.0ta's Avatar
Lift is 649 I believe and I don't know where they was purchased a guy I had install them bought everything together heads are tfs 235 s on a stock 6.0 with tfs hardened 7.4 pushrods keeps breaking springs and bending pushrods
Old Apr 22, 2014 | 06:09 PM
986.0ta's Avatar
Oh sorry heads where purchased late Feb early March 2013
Old Apr 22, 2014 | 06:20 PM
ls1CANTU's Avatar
Stay away from LSK crap. They are good to beat up your valvetrain
Old Apr 22, 2014 | 06:25 PM
Those are from the new spring vendor that TFS started using in 2011.
You could use the original springs that were used in those heads from 2006-2010 which are our Max Pressure springs since they'll work with your retainers. http://www.briantooleyracing.com/650...l-springs.html
Or you could switch to a PAC 1207X spring kit that we offer so you have more room to play with. http://www.briantooleyracing.com/700...retainers.html
Old Apr 22, 2014 | 06:27 PM
7.400" is the wrong length for TFS heads typically unless you have Morel lifters. Even then that would be pretty short.
 Michael S. Palmer
Old Apr 22, 2014 | 06:30 PM
986.0ta's Avatar
What cam would u suggest I know heads are as bit much for my application and I've been told to go with the bt Platinum 660
Old Apr 22, 2014 | 06:32 PM
We typically use .630" or less lift with the Platinum springs with great success.
What's your total combination, I'd be glad to recommend something to you.
You can also purchase through one of our dealers.
Old Apr 22, 2014 | 06:39 PM
96capricemgr's Avatar
The fact you think lift capacity is THE spec to look at says you should get ahold of a professional and just trust them because you don't understand valvetrain. Lift capacity is just one critical spring criteria, how much open and close pressure the lobe needs for a given rpm with the valvetrain mass is HUGELY important and completely ignored if you just look at peak lift capacity.
Old Apr 22, 2014 | 06:47 PM
986.0ta's Avatar
I thought I had a professional doing the work and now I'm having problems. I'm trying to figure out what's up
Old Apr 22, 2014 | 06:49 PM
986.0ta's Avatar
Brian it's a stock 6.0 m6 trans am with tfs 235 s 410 gears and spec 3+ clutch
Old Apr 22, 2014 | 07:19 PM
986.0ta's Avatar
Just saw your post Brian that 7.4 are too long that explains alot
Old Apr 22, 2014 | 08:56 PM
JakeFusion's Avatar
Super Hulk Smash
7.4 are too short. You typically need 7.5" but you should measure to be sure. If you're breaking valve springs you're valvetrain is most likely setup wrong. What rockers, lifters, and do you know installed height on the spring?
Btw those are either PAC 1904s or 1905s. The 1904s are wrong for the LSK lobes, but the 1905 would work.
Old Apr 22, 2014 | 09:06 PM
986.0ta's Avatar
Stock rockers with supposedly ls 7 lifters atleast I paid for them
Old Apr 22, 2014 | 09:10 PM
986.0ta's Avatar
I took the mechanic 5400 to do heads and cam with supporting stuff and it came back like this I was scared to mess with the ls engines didn't know much about the. Used to sbc
.boB's Avatar
Springs and other valve train components break when two solid objects attempt to occupy the same space at the same time. Simple physics, in theory. In actuality, you have to figure out why and where that is happening, and what to do about it.
Also, the valve train is really rather simple. It's simple geometry. Remember the game of Mouse Trap? it's like that. One action leads to another, which leads to another, and so on.
If the push rods are too long, they will hold the valves open when they should be closed. That results in poor performance, and backfiring through both intake and exhaust. If the valves are held open too much, they'll contact a piston and bend the valve. Or worse.
Bent push rods are caused by a variety of reasons. Usually it's something obstructing the full movement of anything between the lifter and valve face. The push rod is often the weakest link, and that bends first.
If you're breaking valve springs, that's usually caused by coil bind. That's when the springs are stacked up so tight they can't be compressed any more - the spring coils are attempting to occupy the same space at the same time.
Installation of aftermarket springs with an aftermarket cam MUST be done with a micrometer. MUST be. There's no way around that, unless you're willing to WAG it. Which it sounds like your "professional" did.
It's a simple math problem. Coil bind height+0.050"+valve lift = minimum installed height.
Old Apr 22, 2014 | 09:15 PM
986.0ta's Avatar
The springs came with the heads which he supposedly told them which cam
Old Apr 22, 2014 | 11:04 PM
GrannySShifting's Avatar
Get rid of the cam, put the Max Pressure springs on it like Brian said, and you will be good too go. What rockers and valve guides do you have? Any "pro" that would choose a MS4 cam with that setup is not a "pro" in my book
