228r and Stock Oil Pump Concern
Old Apr 23, 2014 | 08:58 PM
jarjarlol's Avatar
Default 228r and Stock Oil Pump Concern
I recently finished installing a 228r cam package with push rods and PRC 1518 .625" springs (stock ls1 lifters) from TSP and was wondering is it safe to spin my motor to 6500-ish rpm's on the stock oil pump? I know I know.... I cheaped out and didn't get it ported or buy a melling. The motor has 68k miles on it and runs like a top. I get a little over 40 psi oil pressure at idle and a little over 60 at redline as it sits now. Any thoughts or insight is much appreciated.
Old Apr 23, 2014 | 09:08 PM
conan's Avatar
Nothing wrong with what you have, 60psi is plenty of oil pressure... Let her eat.
baronsmith98's Avatar
Only one way to find out! Ha
Old Apr 23, 2014 | 10:37 PM
LilJayV10's Avatar
FWIW that's the same PSI I had on my engine w/ 45k when I did my H/C/I swap, no problems at all.
Old Apr 24, 2014 | 12:49 PM
gagliano7's Avatar
You will be fine. More people have trouble when the change oil pump and screw things up.
Old Apr 24, 2014 | 01:41 PM
CHEVELLEPOSSE's Avatar
I'm with the post above me ,By the way the Mellin high flow is not the pump to go with I had to hack my front cover for it to fit with double roller chain. As long as your psi is where it's at your fine
Old Apr 24, 2014 | 03:08 PM
poltergeist 02's Avatar
I'm running the stock pump in my motor. I have the same pressures that you do with no problems. what year is your motor?
Old Apr 24, 2014 | 03:43 PM
Im running melling high volume got 50 psi at idle and 75 at redline
Old Apr 25, 2014 | 01:31 PM
Camarokid327's Avatar
I am about to install my 228r this weekend and was wondering if my stock oil pump (ls6 style I believe since its a '02) would be fine. Car has 61K babied miles and is a 2002 SS. Looks like I should be okay with keeping the stock one!
Old Apr 25, 2014 | 01:42 PM
conan's Avatar
Run it... Nothing to worry about.
You don't start trashing parts in the motor untill the oil pressure drops below 10psi. So everyone with 40-60psi is just fine... You don't have to have 100psi of oil pressure to keep a engine alive.
