lifter preload
Old Apr 26, 2014 | 08:03 PM
tom70's Avatar
Default lifter preload
building an lq9 with 243 heads, hr288 comp cam, ls7 lifters. what lifter preload does every one prefer? .050? measured push rod length today and came up with 7.300. what push rod should I get?
thanks
Old Apr 26, 2014 | 08:24 PM
Darkman's Avatar
Although 0.050" or even a little less will work, based on the threads here that I've read, I believe the recommendations for preloads on the LS7 lifter run from 0.060" to 0.100" with 0.080" being a popular target.
Old Apr 27, 2014 | 11:29 AM
KCS's Avatar
KCS
Moderator
I went with ~.080" for preload on my LS7 lifters.
Old Apr 27, 2014 | 05:51 PM
baronsmith98's Avatar
I have around .080" on mine as well and the valvetrain is very quiet
Old Apr 27, 2014 | 10:09 PM
LilJayV10's Avatar
thanks
That's a pretty short pushrod. Are the heads milled or using a thinner head gasket?
Old Apr 28, 2014 | 08:44 AM
PREDATOR-Z's Avatar
Could you clarify the 7.300 measurement?
Was that actual measurement not taking pre-load into account?
If so get at least 3.375 or 7.400 will work.
