pushrod length
Old May 2, 2014 | 05:38 PM
george88gta's Avatar
Default pushrod length
Plan is to install a set of 799 heads on my LQ4. The heads have not been cut. I have a set of gaskets that are 0.010" thinner than the stock gaskets. I have the comp cams pushrod tool so I will be doing the measurement. Just looking for opinions/comments, is it possible the stock pushrods will be OK or is there a possibility I will need a new set? The stock pushrods are new, but I will order a new set if needed.
Old May 2, 2014 | 08:11 PM
Darkman's Avatar
Measure. The odds that the stock pushrods will be ok are high - based on what you have reported.
