gto upgrade dyno sheet.
Old May 16, 2014 | 10:59 PM
ur-n-8's Avatar
Default gto upgrade dyno sheet.
Have a 04 gto ls1 motor that I upgraded over the winter. I milled and ported the heads, I installed a Lunati 20540711 cam and a underdrive pully. It's running through some homemade 1 3/4" long tube headers and a 3 and 1/2 single. Anyway I finally got it tuned and a dyno sheet. The tuner seemed to be happy with the results. I was just hoping for 400 rear wheel so I guess I made that.
Old May 17, 2014 | 07:52 AM
redtan's Avatar
That dyno looks whack...the hp curve falls flat on it's *** while the torque curve keeps going. Usually it's the other way around so maybe they got switched.
Anyway, depending on the size of the cam those may or may not be good numbers. Although those tiny homemade headers are probably hurting you quite a bit.
Old May 17, 2014 | 08:59 AM
poltergeist 02's Avatar
It looks like that because the hp numbers and the tq numbers on the graph don't line up straight across. If you look at the 400hp mark on the left, it lines up with about 387tq on the right.
