LS1 Valve Lash Procedure?
Old May 17, 2014 | 08:01 PM
tron_'s Avatar
Default LS1 Valve Lash Procedure?
I am in the process of building an LS1 for my 1993 Nissan 240sx. Here is a list of relevant mods:
-TSP 228R cam
-TSP stock length push rods
-PRC stage 1.0 heads
-LS7 (I think) hydraulic lifters
-Stock LS1 rockers
I was wondering if there was some info out there as to how to set my valve lash on this engine. I know on a stock LS1 you can just torque everything to 22ft-lbs and call it good but I was wondering if I could get away with that here.
Thanks!
Old May 17, 2014 | 08:45 PM
Darkman's Avatar
https://ls1tech.com/forums/7957678-post2.html
Old May 17, 2014 | 11:57 PM
big hammer's Avatar
-TSP 228R cam
-Stock LS1 rockers
Thanks!
basically after zero lash, your rocker bolt needs to tighten up between 1\4 to 1 full turn.
Old May 18, 2014 | 09:42 PM
tron_'s Avatar
Originally Posted by Darkman
Forgive my lack of understanding here but doesn't this article explain how to measure push rod length?
Old May 18, 2014 | 09:46 PM
high impact's Avatar
Pushrod length determines the preload. Technically op isn't setting lash, he needs to establish the correct preload since it is a hydraulic cam. Lash is used for a solid lifter.
