98 formula ls1 6 speed first build help
If you guys could please help i have a list of questions, if you could just answer some that would be a great help. Please and thank you guys!
- Is 400rwhp+ (reliable) possible with 2500 in the motor? if not how much $?
- I like the stage 2.5 ls6 heads with the magic stick 3 cam shaft, single behive valve springs, and upgraded oil pump package from texas-speed.com (2000$)
- Is it any way possible that i could re-use the stock pistons/rods/crank as long as they look okay and if i am pushing 400+ to the wheels?
- If i run the package set up that i listed above can i run pump gas?
- should i do any maintenance to the t56 (117k miles) if it shifts good?
Notes: Im all open to ideas and comments. You guys are the ones that have the built cars.. im just trying to join the club. Im just looking for some advice.
Thanks so much guys.
