GM Hot cam questions
FYI,
Don't let the lift scare you away, the lift doesn't make the cam aggressive the ramp rates do.
http://www.mcssl.com/store/cammotion/the-titan1
http://www.mcssl.com/store/cammotion/the-titan2
http://www.mcssl.com/store/cammotion/street-slayer
http://www.ws6project.com/user_stor/...e-rpm-220-224/
http://www.ws6project.com/user_stor/...-lift-222-224/
http://www.ws6project.com/user_stor/...20-220-112lsa/
http://www.ws6project.com/user_stor/...oducts_id=4640
FYI,
And yes there are many better choices than the hot cam. I titan 2 or streetslayer above would also be a nice choice for what you want. Just keep poking around choose what size you think you want and then go one step bigger lol
"Just keep poking around choose what size you think you want and then go one step bigger lol"
Is that kind of like a car too fast? No such thing? LOL
Yours being a A4 your first stop needs to be a converter a converter will add a world of difference especially with crap 3:23 gears even on a stock cam. Sticking a large cam on a stock converter will yield a car that sounds good but is a complete dog out of the hole and even for daily driving until you can get enough rpm built up. 3:23's with converter is tolerable if you dont want to change them.
I say go with hotcam it sounds like for the way you intend on using your car it will be about right and when tuned correctly they are great I've had several and liked them. If you look in my sig I'm running a GM ASA cam in my car and love it. And I don't have to worry about valvetrain reliability.
Order you go is
converter
gears
cam
Order you go is
converter
gears
cam
Keep the valvetrain light and match your springs with the cam and you'll see many trouble free miles. No matter what cam I go with I would always check my springs at 30k even the hotcam has more aggressive lobes than stock and offers larger duration. And even so it takes all of an hr to pop off a spring and have it checked.
With .525 lift its also leaving a good chunk of power on the table, modern cams like eps offer almost the same ramp rate to be easy on springs but will make much more power and drive better given similar duration.
Sorry if any of that sounded like I was being a dick :/ just stating for what the op wants he can do much better than a hotcam and not really lose anything but actually gain power and driveability over it.
I know some cams have be recommended here. Will probable be getting a converter with a stall speed of around 3200 PRM. Will the recommended cams work good with that? Or should I maybe consider different cams with regards to the stall speed? Again this is a street driven car that will only see the track every now and then. The goal is NOT a full blown race car but something that is reasonable to drive on the street and can run respectfully when taken to the track on occasion.
Go with the milder version(222/226, LSA111+2, .602"/.605") it also has 2* overlap.
http://www.tickperformance.com/tick-...1-ls6-engines/
This is in a LS6 long block but you get the picture.
https://ls1tech.com/forums/dynamomet...k-results.html
If you're looking for a good budget converter look into the Edge "Street" series.
