Advice please
Old May 25, 2014 | 05:18 PM
vht's Avatar
vht
Default Advice please
I'm building a 6.0 turbo for a 88 foxbody. Engine is out of a 2000 trk. Trk oil pan is to deep so I ran onto 1 that will work, brand new, with windage tray, dipstick, and pick up. He also had a flywheel, new also. the 1 off my 6.0 has round holes around it where this 1 has 3 round and 3 oblong. It is heavier made with a reinforcement ring a round it also. Everything else looks the same. Will this work on mine? This stuff come off of a new crate motor, don't know the yr. The guy I bought it from said a friend bought the crate motor for a 57 chevy, ordered a pan and stuff from Summit to fit the 57.
Old May 25, 2014 | 05:40 PM
JoeNova's Avatar
Restricted User
The flywheel is going to depend on which transmission you are running.
Old May 25, 2014 | 06:00 PM
vht's Avatar
vht
I'm going with a PG and was going to oblong the holes like I've heard mentioned on here. My 6.0 has the long crank which is my understanding will not require a spacer. I think this flywheel is the same, I just never seen one that is this beefier.
