Ls1 oil pressure issues
Old May 26, 2014 | 08:28 PM
Tdadddyz28ss's Avatar
Default Ls1 oil pressure issues
Hey guess I have a 98 camaro ss with 84k miles. And I live in Texas since its been getting warmer I've noticed a drop in oil psi when warm. Used to it'd idle around 30-38 warm no it idles around 18-25 and it goes up to 30-40 cruising. But it doesn't go above 40 at wot. But when it's cold it has no problem going up to 60-65. the oil is only about 2k old I use 5w30 mobile 1 synthetic and I've checked it. Any suggestions would be appreciated!
Old May 26, 2014 | 09:04 PM
Darkman's Avatar
The Service Manual specification for LS engines is 6 psig at 1,000 rpm, 18 psig at 2,000 rpm, and 24 psig at 4,000 rpm. And it is normal for oil pressure to be higher when the oil is cold and thicker. So your pressure levels are "normal" by GM standards. Having said that my LS engines (with stock oil pumps) generally have more pressure than that. If you want to pursue the issue the place to start is test the pressure with a mechanical gauge to establish whether your current levels are accurate.
Old May 27, 2014 | 08:43 AM
Thank you I was also thinking about trying a heavier weight oil but I was also worried that might have a negative effect if something is already weak having to push something heavier!
